blocked drains
Discussion in 'OT (OFF Topic) Forums' started by DrFeelgood, Jan 24, 2010.
  1. st13phil
    st13phil MB Enthusiast
    8,007
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
    My advice would be to call your Water Co. I'm in the Thames Water area and a couple of years ago I had a foul drain block up on Boxing Day. With 10 guests due to arrive for dinner in about 4 hours time I needed to get something done fast, so called Thames Water who told me that if the blockage was in their pipework it would be a free callout, but otherwise it would be chargeable - fair enough.
    Being between a rock and a very nasty, gooey, smelly, place I figured all I could do was bend over and hope it didn't hurt too much. Boy was I in for a shock! The charge would be...... £65 as long as the guy could clear it within the first 30mins. £65? On Boxing Day morning? OK, says I, you're on! Less than 90 mins later the bloke had arrived, cleared the drain and departed with £65 for them and a tenner tip for his trouble :thumb:
  2. CE230
    CE230 Active Member
    574
    Sep 10, 2008
    Wylde Green
    Car:
    230CE
    Same here and they are under the impression that it is a shared sewer as they have no plans.
  3. Beetnik
    Beetnik Active Member
    538
    Jun 22, 2008
    Yorkshire
    Car:
    Volvo V60 2.4 bi-turbo: SLK 200
    Do you have a large diameter pipe or a thin neighbour? :bannana:
  4. OP
    OP
    DrFeelgood
    DrFeelgood MB Enthusiast
    8,991
    Nov 10, 2005
    Car:
    BMW 740Li
    Just to let you know and so the thread is complete.
    I called Welsh Water and they called out to rod the drains - didn't work as I told them that I couldn't clear this way.
    They, reluctantly, called the next day and cleared from the neighbour's side. Apparently the drain rises slightly under the neighbour's land!
    Anyway, all done and I didn't have to do anything unpleasant a second time. In fact I was up in London while it was all going on.
    2 people like this.
Tags:
Share This Page
