Servicepoint
Each time I try to operate the heated rear window the no 10 red 16amp fuse blows. My concern is that the electromagnetic engine fan is also on this fuse and I potentially run the risk of overheating. Can anyone suggest what I can check to find the fault and perhaps eliminate whether it’s the fan or the heated window? I think the relay for the rear window is behind the instrument binnacle but don’t want to go ahead and change that when it could be something more obvious. The elements in the window appear does in ok condition. Since taking the picture I have changed all the fuses to brass.
