Blue or red antifreeze?
Discussion in 'Parts, Maintenance & Servicing' started by kaitlin, Nov 2, 2018.
  1. kaitlin
    kaitlin Hardcore MB Enthusiast
    111
    May 12, 2018
    Durham UK
    Car:
    Mercedes a180
    hi does anyone know which colour anti freeze my merc a class needs it’s a 17 plate ?
    Justintyme likes this.
  2. markjay
    markjay MB Club Veteran
    20,589
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    You can open the bonnet and check... but the colour is irrelevant.
    The coolant needs to be compatible with MB Spec 325.0 or 326.0 (depending on the engine/year).
    But you should investigate any coolant lose; it's a sealed system so a reduction in coolant level could mean there's a leak somewhere (or a range of othe possible faults).
  3. OP
    OP
    kaitlin
    111
    May 12, 2018
    Durham UK
    Car:
    Mercedes a180
    There’s none in to check my dad thinks it has to be either red or blue if it’s an aliminum or steel engine?
  4. mercmancdi
    mercmancdi Hardcore MB Enthusiast
    332
    Feb 18, 2012
    Templepatrick
    Car:
    mercedes E320 cdi sport
    I think some are green also.
    But I didn’t think it mattered as long as it meets the requirements
    for your temperature drops where you are.
    Justintyme and kaitlin like this.
  5. mercmancdi
    332
    Feb 18, 2012
    Templepatrick
    Car:
    green and orange antifreeze are ethylene glycol-based, the difference between them is that they contain different corrosion inhibitor ingredients or additives. While orange antifreezecontains organic acids, green antifreeze has additives, such as silicates, borates and phosphates
  6. Gazwould
    Gazwould Hardcore MB Enthusiast
    921
    Sep 29, 2018
    Everywhere
    Car:
    S204 C250 CDI AMG Sport
    I gave up in the end , far too complicated , so I put beer in .
    Keeps me cool in the summer and I never froze up, even when subjected to the 'Beast from the East' earlier this year .
  7. OP
    OP
    kaitlin
    111
    May 12, 2018
    Durham UK
    Car:
    Mercedes a180
    haha
  8. OP
    OP
    kaitlin
    111
    May 12, 2018
    Durham UK
    Car:
    Mercedes a180
    Apparently so, he put red in so fingers crossed it’s the right one
  9. markjay
    20,589
    Jun 24, 2008
    London
    Car:
    Where did it go?
  10. OP
    OP
    kaitlin
    111
    May 12, 2018
    Durham UK
    Car:
    Mercedes a180
    It must have been empty i didn’t realise i had none in!
  11. grober
    grober MB Club Veteran
    25,579
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  12. clk320x
    clk320x MB Club Veteran
    8,580
    Sep 27, 2016
    East Midlands
    Car:
    W212 E250 Sport - W211 E320 CDI Estate
    You have a leak somewhere then. Also if you fill a system which has some red coolant with blue coolant, or vice versa, the mixture will form a jelly.
  13. Justintyme
    Justintyme Hardcore MB Enthusiast
    301
    Feb 3, 2018
    Ireland
    Car:
    Mercedes Benz w212 E Class
    And then Kaitlin...( and not wishing any bad luck on you... )..you will have trouble !!! Better find out the correct antifreeze for your car, and do ( or have your Dad do) a complete drain and flush. Its not that difficult.
  14. Justintyme
    301
    Feb 3, 2018
    Ireland
    Car:
    That's what's called " Advance Planning, and Prior Preparation, in order to avoid the dreaded PPP" Personally, I'm a great believer in it !!!:):D:cool:
  15. chrisk2010
    chrisk2010 Hardcore MB Enthusiast
    707
    Oct 1, 2014
    Essex
    Car:
    C230 w203
    My VW was purple! If you can stretch to it go for Mercedes or double check for right spec it shouldn’t be to expensive.
    v8sam likes this.
  16. johnsco
    johnsco Hardcore MB Enthusiast
    1,901
    Nov 22, 2008
    Leeds, West Yorkshire
    Car:
    E280CDI SPORTS ESTATE
    The important point is that loss of coolant is a serious matter.
    If you run your vehicle with too little coolant, your engine will overheat with disastrous (and very expensive) results.
  17. Gazwould
    921
    Sep 29, 2018
    Everywhere
    Car:
    So that will be G13 and before that G12 that was pink , both are miscable .
    So simple unlike MB's array of fruit juices .
    chrisk2010 likes this.
  18. chrisk2010
    707
    Oct 1, 2014
    Essex
    Car:
    C230 w203
    That's right :thumb:
    Bleeding the air out the golf was a right mare too left it running with the cap off for an hour until it sorted itself out.
  19. brooklands51
    brooklands51 Member
    52
    Oct 8, 2018
    London
    Car:
    W140 S600, C208 CLK55, C124 E320
    :eek:
    1. ring any MB dealership
    2. ask for parts department
    3. quote your reg
    4. buy the right coolant.
    stwat likes this.
  20. clk320x
    8,580
    Sep 27, 2016
    East Midlands
    Car:
    How would they know what’s currently in the car? It could have been changed
Share This Page
