Bluetooth Question
Hi Jav. Basically if you stick to Nokia you want SAP. If you like to change your phone around different makes(blackberry, iphone, etc) then you'll be better with the HFP.
It had a nokia cradle but the last owner took it out. soo would B67875877 fit where the cradle used to be?
You don't mention the car model year but I'm assuming it has UHI, the previously installed Nokia cradle was attached to a small connector at the centre armrest area? In this case both BT adapters work on your car, the BT HF one equally as the BT SAP adapter.
I prefer the BT SAP version with a privacy handset. Depends a bit if you often talk with others in the car. A handset gives better audio quality too although BT is OK and needs to be OK because that is what you want to use mostly.
