BMW specialist in west midlands
astamir
london
w208 silver clk55
Hi guys
Having a problem with friends 2006 bmw 320es 2ltr petrol and needed an experienced bmw specilaist in west midlands the car in wolverhampton at the moment.
The car in limp mode with EML on with codes p1062 and p2610.
Thanks in advance guys
MSL in Birmingham deal with BMW's. Give Acid a call and see if he can help.
astamir said:
Hi guys Having a problem with friends 2006 bmw 320es 2ltr petrol and needed an experienced bmw specilaist in west midlands the car in wolverhampton at the moment. The car in limp mode with EML on with codes p1062 and p2610. Thanks in advance guys
This will most probably be the valetronic sensor that needs replacing this is the sensor that controls the variable valve timing and it needs doing asap or it wrecks the engine it's also a difficult job to do the 2610 code is the fact the ECU knows the timing is not correct which will be due to the faulty sensor any decent garage can sort his for you doesn't have to be a BMW indie if there is not one near
Drop in on bimmer forums lots of info and advice there
Got a quote in £475 for camshaft servo motor replacement including everything.
The place called BMeuroservice is that a normal price for this job?
