When tightening/untightening wheel nuts on W211 I am getting extreme shock waves. So the resistance does not increase uniformly as the bolts are tightened but there are lapses in resistance causing shock waves. Similarly when tightening.
I applied copper grease to bolt threads but it did not help. I now believe that these shock waves are due to friction between RAD bolts and rad seats of the alloy wheels.
It might be that I am over-torquing but on the other hand if the perceived torque is provided not through thread tensions/friction but through rad seat friction I fear that stopping as soon as the 110Nm is reached could lead to not properly tightened bolts.
I am thinking of applying copper grease to the RAD surfaces as well. I think it will result in the torque increasing continuously as bolts are tightened with no sudden lapses in torque as bolts are tightened that cause shock waves. This will also allow me to stop at 110Nm or so in confidence that torque is not about to collapse if I tighten just a bit more.
What are the views on this?
