The diagnosis MB from this error:
It seems to me that there are not ...
This sensor can be cleaned? How?
I have verified that there are traces of oil aspiration, they may have damaged it?
Do you think the problem is the map or something other?
Code:
0105-001 Check the pressure transducer B5 / 1. The boost pressure is too high.
Check (instruction from stardiagnosis machine):
The atmospheric pressure and the suction pressure (with ignition ON and engine off) should not differ by more than 30 mbar (30hPa, 3kPa).
I checked the value and have a maximum deviation of 1kPa.
solution:
Check for loose contact on the cables between the engine control unit and the sensor.
