al212
I've just recently bought a second hand S212 2015 eclass estate - car seems to be in pretty good order, apart from some electrical issues.
The reverse camera doesn't work at all - no change to command screen when in reverse - I also can't see any reference to the camera under system settings - From what i've read there should be a way to confirm that the camera is on when reverse gear is selected? All the sensors seem to work.
I've also just today noticed two cut wires next to the RH hinge of the boot hatch (see pics) one goes to a USB mini connector of some sort the other thinner one, I can't tell. I also noticed that one of the soldered connectors to the heated rear screen has apparently been cut.
I'm completely new to these cars and not particularly hot on any of this - I'll likely take it to a specialist, but does any one have any idea what these cut wires could be and also does the cut wire to the rear screen mean that is not working? Is there a way to test this?
Any help/advice would be greatly appreciated the car is still under warranty with the garage i bought it from - not impressed that none of this was disclosed so will be going after them!
