Boot light on a W124 coupe (1994) needs replacing
mattc
Midlands
Audi A4, 1994 E320 Coupe, 1995 E300 estate
Hi All
I am sure this is a simple one but i cannot get the cover off the boot light(no manuals) and I don't want to 'force' it 'cause that will just end in tears:o . Could somebody tell me what the technique is please?
cheers
mattc
p.s. which workshop manual wouls people recommend i get?
just need a small screwdriver under one side and prise it out carefully as there is a small tab either side. (longitudinally)
Thanks Sp!ke - knew it would be simple but was wary of spannering it with a ham-fisted approach (and no- I still have not changed the seat belt presenter yet!)
A sp!ke is very useful for this job
Are you sure the light actually needs replacing ?
Its common on the w124 coupes for the wires (to the light) that run inside the boot hinge to become brittle and break inside the hinge over time , this will lead to the light not working ....
H
I agree with Howard as mine did the same and took me ages to work it out. Me and electrics? :crazy: not the best of friends.
hhmmmm...guess the easiest is to change the bulb. When that does not work I can decide whether it is worth trying to find the offending wire (that will be NO then!).
cheers guys; here's hoping it's the bulb.
