Two 202s
- Feb 18, 2011
- c200 c240 xk8
Hi folks, I just bought another 202. this time a 97 c240. Pretty nice car, but need some help if you could with a couple of issues.
The ABS and BAS lights are on. From what i've read, it could be the pedal switch or a wheel sensor,
Secondly, the indicators flash double speed. This affects both sides, and the rear ones seem really dim, made worse by the smoked lenses.
The indicators all function normally when using the hazord switch.
I have checked the bulbs are the normal 21w type. Wondered if the flasher unit was at fault, but not sure where it's located.
Any help would be really appreciated. Cheers, John
ps. I'm going to have to let the C180 go now. What do you think this is worth 1995 MERCEDES C180 AUTO BLUE on eBay (end time 30-Apr-11 20:19:09 BST)
