ched999uk
I have the bouncy lock syndrome!! Finally managed to get a dry day and attack the passenger door lock on our C230K coupé 2003 (pre facelift). Boy what a g1t. I read lots on here and other forums/youtube etc. Non were on a coupé and it is different. There are 2 speakers in the door and as it's a pre facelift the door pull does not need to be removed to get door trim off. There is a plug concealing the screw under the bottom of the door handle. I only found that after I broke the outer part of the handle!
Anyway I could not extract the lock actuator but did manage to fit the new spring through the rear speaker hole. The old spring was broken and I checked the new one against the old broken one to make sure it was correct one (for passenger door). Put it all back together but still same problem.
So bouncy lock not fixed by new spring (unless I did something wrong?).
Any ideas?
Thanks and Merry Christmas.
Any ideas?
