Is there any way of opening the box behind the drivers seat if the PSE pump fails when the box is locked and you need to replace the 20A fuze for the PSE pump on a R230 SL500
You can't open the lid, but if you move the driver's seat all the way forward, you'll see a rectangular panel mounted vertically in the carpeted area. That unclips (use a big screwdriver) which then gives you sight of the fuses end on.
The PSE fuse is the yellow 20amp, just left of centre. Long nose pliers are the easiest way to get at it, but thin fingers will also work!
