Brake Calipers for rear W124 1992. 200 Wanted
Discussion in 'Classifieds - Wanted' started by Ponton-Jetronic, Jul 2, 2017.
  1. Ponton-Jetronic
    Ponton-Jetronic Active Member
    65
    Dec 13, 2011
    Ireland
    Car:
    W124 200TE
    Wanted. Rear Brake Calipers to suit W124 estate 200 petrol - aprl 1992 auto. Will consider good used or new item. North ireland.
    Give full details and photos if possbl. Many thanks.
  2. optimusprime
    optimusprime MB Enthusiast
    3,199
    Dec 29, 2013
    Kidderminster Worcestershire UK
    Car:
    Mercedes W124 260E M103
    Try the breakers over in your location . Also i think you need to find out just what type the calipers are .I found that two types were used .If you can look at them in your hand, then you will then have the right set for your car. Or check the numbers on your calipers ,and go from there.Check out the sales section on the forum for members thats are seling parts .
  3. optimusprime
    3,199
    Dec 29, 2013
    Car:
    Ponton i can give you the numbers and like i said 2 types were made if you can find out what make they are it will help you . Left rear 2014200283R Right rear 2014200383R .. .. 1294200283R .. .. 1294200383R Check this in the GERMAN STAR site just google it and click on mercedes benz parts catalog ..then click on w124 on the left let me know if you find it.
  4. OP
    OP
    Ponton-Jetronic
    65
    Dec 13, 2011
    Ireland
    Car:
    W124 200TE
    Thank you Optimus...will check out these numbers in a.m. when workshop reopens.
    And will find the make. On sat I was supplied with a Pagid set [ costly ] which are wrong. The old calipers are pitted and seized, even though car is in regular use. This help is appreciated.
  5. optimusprime
    3,199
    Dec 29, 2013
    Car:
    Ponton get them serviced and rebuilt .You say they are pitted, is that in the bore of the caliper ?..If so then they will be scrap . Pick a pair up from breakers .Or speak to a seller on ebay thats breaking one down .. Or a member on the forum ,thats the best bet .Then replace the pistons seals and rubber boots .
  6. JC220
    JC220 New Member
    20
    Aug 29, 2013
    Ireland
    Car:
    2007 W211 E220CDI, 1992 500E, 1990 300E-24, 1995 C36 AMG & 1987 E36 AMG (project car)
    I have a pit of good used low mileage w124 200 rear calipers & I am based in Northern Ireland. Let me know if you are interested
Share This Page
