It's probably the brake pedal travel sensor in the servo.
My W210 started giving these two errors last week.
Both the ESP and the BAS reported a malfunction at the same time just after starting up from cold. After switching the engine off then restarting, it didn't happen again until today. I ignored the messages until I reached my first destination a mile later. After switching off then on again, the fault disappeared.
I can't remember if the malfunction messages came on before or after I pressed the brake. If the problem is related to the brake light switch, would it only become apparent after pressing the brake pedal, or would the fault be found without pressing the brake pedal?
I suppose it needs the fault codes to be checked?A whole number of things. Like a wheel speed sensor.
