Brake fluid change SL R129
RichardF
Sl 320
Hi I have a 94 R129 SLwith ETS. Can I use my Eezybleed with this?
The Eezybleed will operate up to 20psi, although due to it's flimsy nature I prefer to keep it below 15.
I've heard R129s should be bleed @ 2 bar although I'm not sure if that's just for the ASR/ESP models.
I've routinely used my Eezibleed at 25-30 psi without any problems (2 x old Audis, MR2, CLK).
I think the issue is pressure forcing the brake fluid reservoir away from the master cylinder. A couple of tie-wraps makes sure that doesn't happen.
Ian.
Thanks chaps. The last time I used the ezybleed at a higher pressure one of the pipes came off and it ****** fluid all over the place.
15 PSI worked fine on these. :)
