johnlewis1964
- Aug 17, 2017
- 2008 C180 Kompressor.
Hi folks do Mercedes cover this as part of their 30 year warranty tia. SORRY 2008
Cheers They did the subframe last Dec and never mentioned the corroded pipes and car failed the nct lolDoubt it , as far as I am aware it's just body work , might be worth a try though , while you are at it ask them to check for the dreaded corrosion on the rear sub frame .
Mercedes Benz replaced the rear sub frame and did not do the rear brake lines at the same time ??Cheers They did the subframe last Dec and never mentioned the corroded pipes and car failed the nct lol
As others have said. MB will not cover this, the corrosion warranty also requires annual checks by MB and only covers perforation of body panels and, sometimes items such as subframes.Hi folks do Mercedes cover this as part of their 30 year warranty tia. SORRY 2008
Under warrantyMercedes Benz replaced the rear sub frame and did not do the rear brake lines at the same time ??
