- Jun 20, 2011
- S204 250CGI Sport
No mate, get some emery cloth on it, it will clean up good as new, once you`ve done that get something on it, grease, copper grease, spray wax.
Please dont do that. We see a few pipe failures because people can't be bothered to get them fixed. Brake pipe failure is not a good thing!No mate, get some emery cloth on it, gently, not too rough, it will clean up good as new, once you`ve done that get something on it, grease, copper grease, spray wax.
£10 worth of brake pipe, plus unions and the flaring of the pipe does mount up. Have you seen the location of the rear brake pies on Mercedes? Some require the subframe to be lowered and this takes hours.Honestly ive no idea where some of todays garages get the freakin prices, they`re all in cuckoo land, i got quoted £250 to replace £10 worth of brake pipe, you can ordered ready made up pipes on e-bay from £5.
When a brake pipe shows signs of failing they tend to swell due to the walls of the pipe becoming so thin due to corrosion, ive seen pipes that look 10 times worse than the OP photo brush up like new, and once youve cleaned the pipe back to clean metal you simply cannot leave it bare to tackle the elements.
This is just my opinion, you are all entitled to yours, but that pipe in the picture does not look bad at all, it looks a lot worse that it actually is.
In my opinion.
I had the inevitable brake pipe corrosion mentioned on the last few MOTs on the 124. Until this year Ollie (Black C55) thought they were ok but this time he felt it had gone far enough and needed to be sorted. It wasn't helped by failing on a n/s rear wheel bearing with a huge amount of play in it although it still drove and handled normally. The bearing wouldn't come out and a new hub was needed. So given that it needed to come apart and it was 25 years old and had 181000 on the clock we (ie Oliie) suggested pretty much rebuilding the rear end. So new hub, wheel bearing, brake pipes, all rear bushes to subframe and suspension, differential seals, bushes etc, rear silencer and a few other bits I can't remember. On a positive note the self levelling pipes were fine and did not need changing. Looking at the parts removed it was amazing to see just how worn the bushes were but in testament to how the 124s were built they still performed as they should. So hopefully good for another 25 years now.
I have nothing but praise for the team at PCS who have looked after this car for the past 10 years. It now needs new tappets having started making a dreadful noise three days after I brought it back home but that has to wait until they reopen after lockdown.
