Chiffy
Thanks to your previous answers about new pads, discs and fitting kits. I managed to complete one side of the car tiday, however, on the other side, both pins are stuck tight at the head end, I managed to cut off most of pin but have about 2-3mm sticking out!! Can I put a little bit of heat on this caliper to try and remove them??? As if this is not bad enough, they have sent the wrong caliper pins, they are quite short and are not tapered the same as the original ones!!! (see pic). Can I split the caliper easily using the torx bolts, does anyone have a diagram or do they just part easily enough so that I can get a pin punch directly over what is left of the pins???
