Brake Pad Wear Indicator - E-Class W212
Ozboy
W213
The 'Check Brake Pad Wear' warning light on my 2013 e-class illuminated for the first time today and I am wondering what percentage are the pads worn when this light comes on?
Reason for asking this is that my car is due to be part exchanged in a month and I am relunctant to change the brake pads unless it's essential to do so. I do very low mileage, 17,500 miles in 44 months, and not expecting to do more than 400 miles in the remainining time. I am hoping the pads will be okay (safe) during this period.
They'll be fine.
My light has been on for approx 3 weeks and I've done over 1000 miles.
Mine came on today!
My advice is to visually check the pads on both sides of the car with a torch.
There is only one sensor per axle and we recently found that the rear side without a sensor was more worn than the other side - so the warning did not come up on the dash and caused a bit of damage to the disc (which was corrected by having it refaced)
Luckily, I was only a few miles from the garage when the brakes made a graunching noise!
Cheers
Steve
I had a a quick look through the spokes of the wheel and the rear looks more worn than the front. I reckon there is around 4mm left in the front and around 2-3mm in the back. few questions:
Do the inner pads wear at the same rate as the outside?
How think is a new brake pad?
Is the rate of wear linea?
The sensor goes into a hole in the pad, and there's loads of pad left through the width of the sensor and beyond. Honestly you've got thousands of miles left before you get down to the backing plate.
Even then you can still brake safely, it'll just make a grinding noise and ruin your disk.
Not exactly, but almost. There's usually a bit of a difference. The bigger concern is that there's normally only a wear sensor per axle. So one at the front right, one at the rear left, or vice versa. So you'd want to be worried the front left isn't severely more worn than the front right. (drivers side normally wears slightly faster than the passenger side).
The "meat" on it is about 20mm.
The material is the same from the backing plate outwards, so I'd guess so. Caveat, some pads have a coating on the new surface that's more abrasive, and causes "bedding in" to occur more rapidly, so that probably 0.2~0.5mm is kind of sacrificial.
See here: The warning is triggered as soon as the disk touches the electrode of the sensor, but there's plenty of meat around it through the thickness of the sensor and slightly beyond.
Thanks Mike, that makes a lot of sense.
dont brake . :bannana:
