Paragon1970
Hi Folks,
I hope someone can help.
My S211 E280 2008 Estate has this weird issue on the offside brake caliper and disc.
When rotating the wheel it partly rubs in a certain place which makes a shhsh shhsh shhsh noise while driving, particularly prominent when creeping along in traffic.
Can also be witnessed when jacking up and rotating the wheel.
Things done, removed wheel, rotated disk by hand and notice a side to side movement of the disc which corresponds to the rubbing at the inside pad closest to the cylinder.
Suspected the discs were warped so forked out for a set of new ATE discs and Telstar pads.
After fitting the new components I still noticed that the disc is not running completely true, there is a slight side to side movement but it does not seem as pronounced as the old disc.
Problem is I am still noticing the noise after replacement.
Anyone have any idea what the problem could be?
Kind Regards.
Kind Regards.
