Sam204
Hi all. I’m really hoping someone could advise me. I have a 2012 C220 cdi w204 and last week it passed an MOT without an advisory. Drove home to find I had no brakes.
Long story short they had corroded excessively under the passenger side and were leaking. I had to leave the car a few days until the weekend when I could replace the brake lines. I replaced the rear brake lines for copper all the way from the ABR unit back, I also replaced the nearside front brake pipe while I was at it and the offside front was fine so I just rust cured and painted it. I’m a mechanic and made a bloody good job of the brake pipes.
Heres the problem, I have pressure bled the brakes to death, even while pulsing the ABR module and opening ABR valves via my diagnostics. I just can’t get a decent pedal. Long travel until it eventually bites and sort of works.
I had no issues at all until I replaced the brake pipes. My best guess is there is air trapped in the master cylinder or still in the ABR that won’t bleed out.
I read a thread on here with a guy who had a w212 and had the callipers removed for painting and had the same symptoms as me and he remedied it by bleeding the brakes with the rear callipers removed and moved about to free trapped air. Tried this to no avail.
I worked as a Merc tech for 8 years, love my mercs and have been a tech for 15 years. If anyone has experienced this or could help I would very much appreciate the input. Thanks
