HF2
- Aug 16, 2007
- Location
- London
- Lancia Delta HF Integrale 16v, Lancia Delta HF LS Turbo 16V, C240, C36 ///AMG
One of my brake pipes is leaking and I need to either replace the failed section with copper pipe or replace the whole lenght from the rear to the front of the car, however to replace the whole pipe will require dropping the fule tank as the original route takes all the brake and fuel pipes over the fuel tank. It's a W202 C Class.
1. Can I just replace the failed section with copper pipe
2. If I were to replace the whole pipe without dropping the fuel tank, re routing the new pipe will it result in a MOT failure if the new pipe does not followthe original route
