Brake pipe
mobeyone
E280 S211
Have been told my rear brake pipe has some slight corrosion... very minor but been told to clean it up before it gets worse as it just starting to show.
Whats the best way to do this? and to ensure it does not come back?7
Struggling to understand why a 4 year old would suffer from this....
312 Sprinter
MK
Because some of the basic components Mercedes use are junk. Clean the pipe up with wire wool and grease all the pipes heavily with water pump grease.
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
Give the affected pipe a good scrub with a wire brush to remove any dirt and rust, then smear the pipe with grease. :thumb:
OP
OP
mobeyone
mobeyone
E280 S211
Cheers guys, someone mentioned waxoyl?or is that not necessary?
carat 3.6
In the workshop
Not necessary, grease is best for brake pipes, and fuel lines. Waxoyl is for the protection of the cars underbody which should be fine on a 4 year old merc, I hope.:)
312 Sprinter
MK
Waxoyl is much thinner than water pump grease. The grease is easier to apply and will stay in place better. Waxoyl, or preferably Bilt Hamber Dynax cavity wax is perfect for preserving box sections
