I have been looking for the correct torque for somthing and found that lots of people on the net asked the same question. so here is the torque wrench settings for the brake system.
Mercedes C Class Petrol and Diesel from sept 2000 to may 2007 Based on UK spec.
ABS wheel sensor retaining bolts............................Nm lbf ft
Front Sensor ......................................................25 18
Rear Senson ........................................................8 6
Brake disc retaining screw......................................10 7
Caliper unions .....................................................18 13
All other pipe unions..............................................14 10
Caliper bleed screws............................................. 7 5
Front Caliper mounting bracket to steering knuckle .....115 85
Front guide pin bolts..............................................25 18
Master cylinder mountin nuts...................................20 15
Parking brake cable bolts........................................20 15
Parking foot pedal bolts..........................................12 9
Rear Brake caliper mounting bolts.............................55 41
Road wheel Bolts..................................................110 81
Servo unit mounting nuts.......................................15 11
Servo unit vacuum hose union nut...........................30 22
Vacuum pump mounting bolts..................................14 10
