Brake Vacuum Pump on 814D Van Blowing Oil
Transporter
Staffordshire
Merc W124 E300D 24 valve estate (1994)
The brake vacuum pump on my 814d with an OM364 LA engine is blowing engine oil onto the air filter.
I've dismantled the brake vacuum pump, it's a piston type and the rings on it look OK (they aren't cracked) and the bore of the cylinder looks ok too.
The pump blows a coniderable amount of oil with the sucked out air onto the air-filter. The oil is engine oil; however the brakes seem to work OK.
Anyone had experience this and know what causes it?
