coneybiller
Not sure if I should post separate from my other thread but it is a different subject so here goes:
I've noticed that the brake pedal feels a bit notchy. I've had it where the brake pedal has not returned all the way and partially sticks on causing binding. It's called for me to flick the pedal up with my left foot which then allows it to the top once again. It doesn't do it all the time, but I had to make a longish trip up the motorway recently. I tried to apply the speed limiter which has been working fine (unlike cruise, but that's another thread). The engine would cut out and it was slowing down, even tho the accelerator was depressed. I gave up and carried on without it. Then the ABS/BAS lights came on and a brake lining warning popped up. I was a bit unsure as to what was going on so started to slow down (coasting) and started noticing a bad vibration, which was getting worse and worse and the car seemed to be loosing power! I thought I may have a puncture so pulled onto the hard shoulder. Upon coming to a gradual stop, I noticed the 2 front brakes were smoking like crazy! Looked around the car and found nothing physically wrong. Jumped back into the car and realised the brake pedal had been stuck down ever so slightly, causing the pads to get hotter and hotter eventually melting the wear sensors into the pads!!
Just wondered if anyone else had encountered a sticky brake pedal before? The return Spring seems good and strong, could it be servo or master cylinder related?? I've never heard of this before!
I've just learnt at the mo to keep checking the pedal, but I really need to get this sorted!!
