breaker bar (24", 600mm) with 1/2" drive
Discussion in 'Classifieds - Wanted' started by mattc, Nov 18, 2008.
  1. mattc
    mattc Hardcore MB Enthusiast
    2,579
    Sep 27, 2007
    Midlands
    Car:
    2003 E270 avantgarde, 1994 E320 Coupe
    have seen this and this
    any thought please.
    If any one has a spare thats fine too;)
  2. flango
    flango MB Club Veteran
    10,995
    Jun 10, 2008
    Gods own country
    Car:
    Mercedes SLK R171
    Depend on how often and what you are going to use it for, I have some Sealey & Halfrauds pro tools never had a problem with Sealey but have had some Halfrauds sockets snap.
    If you are going for regular tough use then it would be Snap On, Facom or Mac for me
  3. W210 Fan
    W210 Fan Hardcore MB Enthusiast
    1,434
    Nov 16, 2005
    Godalming
    Car:
    W140 S500L W208 430
    you can never have a breaker bar thats too long, however, if you have a good quality ratchet that can take an extension bar (tube, scaffold pole etc) then get a bit of that,
  4. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    i use the handle from my trolley jack. It comes apart into two so i can choose how long i want it and it is pretty strong. Has got the steering wheel bolt off before... just slots on the end of the ratchet i have
  5. imadoofus
    imadoofus Hardcore MB Enthusiast
    2,859
    May 16, 2005
    Car:
    This and that.
    Not true, actually.
    If, for example, hypothetically speaking, when you were younger you had used an eight foot length of scaffold tube as a breaker on the head bolts of a Vauxhall Viva, only to discover after two of you had spend most of an hour applying all your combined weight and strength to each of the bolts that you'd been going the wrong way, you might, for example, hypothetically feel that the bar had been too long...
    :eek:
  6. Chattonmill
    Chattonmill Hardcore MB Enthusiast
    1,498
    Mar 20, 2008
    Northumberland
    Car:
    S211 E55 AMG
    Surely that would have meant that you were too long at the Bar.........
  7. W210 Fan
    1,434
    Nov 16, 2005
    Godalming
    Car:
    W140 S500L W208 430
    use a longer bar than 8` to undo them, fulcrum and leaverage and all that,
    I suppose too long is when you then started turning the car around the rear axle rather undoing the bolt, then you need a really big vice...
  8. Smiley
    Smiley Hardcore MB Enthusiast
    2,059
    Jun 29, 2008
    hmm, there may have been other conclusions apart from the length of the bar.....
  9. imadoofus
    2,859
    May 16, 2005
    Car:
    This and that.
    OI! :mad:
    :eek: ;)
    Yes, There were... :D
  10. OP
    OP
    mattc
    2,579
    Sep 27, 2007
    Midlands
    Car:
    Really its for the occasional releasing of wheels nuts - not regular use by any means.
    Or should I be looking for an impact wrench??
  11. stevesey
    stevesey Hardcore MB Enthusiast
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    I have a Halfrauds extending wheel brace - comes with 1/2in drive and 2 double ended sockets to fit multiple wheel nuts. Never used it as such but it would double as a breaker bar very well. Looks just like one of these. It was an emergency buy when the Monday after having the wheels off I found I'd put the brace in the tool box and not the boot - sods law being what it is that's the day I had a puncture.
  12. Sp!ke
    Sp!ke Administrator Staff Member
    12,234
    Jun 2, 2002
    West London
    Car:
    SL500 & The Fart Car
    For home use, I'd be tempted with a Halfords professional one since if you do break it, you can wander down your local store and get it immediately replaced, no questions asked. (no receipt required even)
    If you purchase something else online, replacement will be somewhat harder.
    1/2" drive breaker bars do occasionally break their knuckle joints regardless who makes them due to the nature of the job they are undertaking.
    Does this purchase have a specific job in mind like wheel bolt removal for instance or is it just a general requirement for the tool?
  13. OP
    OP
    mattc
    2,579
    Sep 27, 2007
    Midlands
    Car:
    That looks good (and cheap like me!)
    Fair point about replacement; as for its use its just the occasional wheel nut removal.
  14. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
  15. pupsi
    pupsi Hardcore MB Enthusiast
    624
    Sep 28, 2007
    London
    Car:
    W124 E500
    I dont agree with them.
    Always hand tightening and loosening for me!
  16. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
    I'd tighten by hand too but to remove a stubborn bolt at the roadside, this does the job very nicely.
    Its so easy even a girl could use it. :D
Share This Page
