Found them to be good in the past.Why Brembo ?
Thank youYou need to order separately, whether Brembo or Merc
Fantastic, thank you.I expect any wear sensor that is compatible with the car will work with any brake pads - the principle is the same regardless of pad. I run Brembo pads but use Merc wear sensors, they are less than £10 and you know for sure that they will work properly, however if you preferred to go Pagid I don't think you would have any issue
And yes 1 for each axle
Both my cars are all Brembo nowFound them to be good in the past.
I clean them every couple of weeks with soap and water and wax them every 6 months when I rotate summer to winter wheels . I would say what is on the wheels is road dirt rather than brake dust .Are they dusty pads ?
