Broken down car wont start ESP ?
Bombx3
e220
Hi hope you can help my car wont start E220 2003 Diesel it cranks over ok !
It has come up ESP look in manual but i cant find why
Any help Greatly Appreciated
Cheers
Ray
Are you sure it not EPC, electronic polution control?
That warning points to a fuelling issue, like low rail pressure, excess leak off, blocked filter/air in pipe
AA man just tried easy start and it ran ..on his laptop when plugged in it said error upper module control panel but he does not know what this is
AA man gone now lol ,he asked if i wanted a tow to MB dealer i said no thanks
no other errors came up
Must be fuel or sensor related then... Does it smoke if you rev it?
car just started and now got warning light come on for brakes !
Has the car been jet washed recently? Reason I ask is that I had a similar issue where I stupidly hadn't put my ECU cover back on properly, when they jet washed it, water got into the ECU connections and I got all sorts of errors, took the ECU out and dried it and all was good luckily!
Car has now started . while turning the key it said stop mediately due to brake failure then the car started ,i drove it and all was good ,no more warning errors and its going perfect
Totally stuck and what it was
Its now in my mates garage over night to be checked in the morning
Thank you for all your efforts
Mery xmas
