glyn86
- Jan 24, 2015
- 2000 e200
These would be better and irwin are a good make.
http://m.screwfix.com/p/irwin-bolt-grip-nut-remover-set-5-pieces/96028?filtered=true
Thanks that's what I was thinking.but was just hoping there would be an easier approach to it.do you know can them bolts be changed to any other type.be no harm change the lot
Well lads.this little beut decided to snap on me the other day.just the head of it.any ideas to get it out
I've been there all too often ! This is despite removing bolts a couple of times a year and trying copper-slip grease on the threads .
The illustrated style at the top of the thread seem the worst for doing this , but some of the M-B security bolts are also bad for snapping .
On my W126 I replaced the long shaft bolts with shorter ones ( correct thread length but the bolt head was then recessed into the wheel ) .
I have sometimes had success drilling carefully down the centre and then using an extractor , but the bolts are made of very hard metal and I have worn out so many HSS and titanium drill bits .
One time , after wearing out several HSS drills , I resorted to using an SDS hammer drill and diamond tipped masonry bits ! It seems a wrong way to do it , but battering away at the bolt eventually ground it down until the tapered collar separated and I was able to remove the wheel .
Just last year , though I had a security bolt shear its head and one other bolt snap on my S203 and ended up having to cut the wheel off with my angle grinder !
Once you get the wheel off , the remains of the bolt can easily be removed with a pair of mole grips .
