familycarguy
Hi all,
Looking for some direction with a problem I've discovered with the C180 I've recently bought.
So far I've done a full service on it, including a transmission oil and filter change. I've since put a few hundred miles on it and noticed that under certain conditions, it violently cuts the power. Almost giving whiplash.
It tends to do it when cruising at a constant speed and rolling into the throttle. I'm not sure if it isn't kicking down when its meant to, or if its more engine related. It doesn't happen straight away, which makes me think its either the gearbox not kicking down properly and violently slamming into the lower gear, or something boost/fuel/timing related.
The car doesn't have any warning lights on, but I just scanned for codes and discovered a strange one that seems to be pending / archived. After clearing it, it doesn't come back, but then I went for a short drive and it did come back. I don't know if this is related to the bucking issue, but its made me even more confused since the check engine light hasn't come on (it does work though).
Anyone got any advice or experience before I give in and take it to a garage? Cheers.
2013 C180 estate 1.6L turbo petrol 7G auto
