Gareth Kent
- Dec 30, 2014
Hello Ladies and Gentleman, I note from some of the posts a number of you are in the building and development trade. I would greatly appreciate your input into sense checking the following. I am in the process of extending and refurbing my house, relatively big job and am using a well regarded local architect. In summary the work is a two story extension, garage downstairs with small utility at back, two bedrooms upstairs, plus add a bathroom via a dorma and refurb two others and the kitchen. In all its 95sq meters of build/refurb of which 55sq meters is new build, the 40sq meters of refurb is the aforementioned kitchen and bathrooms. Not looking at a super high end spec, mid range is fine. Using the architect we will be doing a detailed building quote to three recommended local builders but in order to make sure plans made are not too costly to implement we have paid a few builders to come and provide estimates. So far we have had two estimates coming in at £1500psm +vat. I am in a north Kent in a town which is typically "taxed" so wanted to see if that sounds high. From checking which?, RICs, Travis Perkins and various other sources, a mid range spec should be coming in at approximately £1200psm / £1300psm in the south east. I am prepared to pay for reputable firms who will act as main contractor but ............ Is that worth an almost 20% premium ? So after all that my question is.... Does £1500psm sound about right ? Long post so thanks for reading.
