vtwin
I’ve had this car since March , and tried several different ways of playing large library’s of MP3. I have tried a 1 TB hard drive with a folder called music and inside that folder is all my bands from AC/DC through to ZZ Top . I probably have nearly 50,000 tracks and everything plays perfect through music match jukebox indoors. In the car however the media section of the HI-FI is flaky at best. I bought a 400 GB SD card and loaded that up and sometimes it plays and sometimes it doesn’t sometimes it can’t find any music on it and others it won’t even see the card. When it does work it seems to take a long time to see all of the folders and make them available to play. Same with the one terabyte hard drive. At the top there is 10cc and the last folder is ZZ Top. Does anyone know how it works? Does it have to log every single track into its own database in order to play? Because if this is so does it have to start again each time I drive the car or does it pick up from where it left off? So eventually every truck will be logged and will be available. I can see all the folders but from S down there is nothing showing in the folders even though there are albums and tracks in them. There is very little technical in the Help files so does anyone know a bit more than I do?
