John_Doe
- May 5, 2011
- C32
Ok help needed badly now. firstly the car is a W202 C230K 1999.
I have two issues and I do not know if these are related but i would guess they are.
I noticed the other day that when i started the car there was a really loud grinding noise coming from the engine bay. If the engine is left to idle for a few mins then the noise goes away but sounds really bad! Unfortunately the only video recording i can do is on a iphone so you will not be able to hear the noise properly. If i shut the engine off and start straight back up again then the noise returns instantly. every time.
This has now led to a second major issue! I have some kind of burning smell coming from my engine! it smells a bit like burnt electrical cables. the smell appears to be coming from the same area as the noise which is towards the lower part of the front of the engine.
I have uploaded the video i did when i first noticed the noise but the stupid loud exhust distorts the engine noise. Hope it helps to give you a basic idea though.
c230 engine grinding - YouTube
