Great thanks for the detailed info guys.
I dont have a problem servicing and maintaining all of the above, the problem being that the previous owner might not have taken such due care and the damage already been done.
If i were to buy the car and 6 months down the line had a bill for 3 or 4k then i would be in trouble (19 yrs old student earning min wage )
From the above post, oil in the transmission and engine harness sound expensiive?
- battery acid (or replace battery).
Mine is a 2003 C270cdi sedan, bought used 9 mounths ago. I had a bad acid smell into the cabin so I changed the battery (close to the air cabin filter), so the smell went out! OK, but I'm asking, due to the fact that this seems a common problem as you said, if the problem is related to a bad battery production in that years?
Thanks so much
PS: now I'm worried about the other problems you said: engine harness,...
I'd stick to the 202....great cars...
I wouldn't go for a C180 purely for the lack of power. I went from a 2L 190E to a 1.8L C180 and wow it took me a good while to get used to the sluggishness of it, at first I thought there was a problem with it then i found out it was just the norm.
- bad battery
They purchased a cheaper series of batteries, it seems. I've changed mine.
>> that was a free recall
- smelly heater core in the heater box
I hope that the smell has been solved with the new battery. Do you/they have changed also the heather core or you are happy with the new Thermotronic and carbon filter?
>> The core was fungus / bacteria infected and smelled like cat pee. The updated core was anti-microbial.
- overvoltage on rear stop lamps causing them to blow
>> The fix is a resistor pack from Mercedes which looks like a short M-F cable
- overcurrent on the front headlamp indicators blows lamp holder
>> Wiring update kit directly to indicator
- heater box footwell flap click noise
>> those plastic arms !
- engine harness oil - fixed with spacer harness
>> A271 part number. Special 10cm cable.
- transmission oil plug update
>> There is a cable that plugs into the sump - the new cable surround prevents the oil into the harness
- fuel line not crimped correctly
>> Just a recall - the smell is a giveaway
I dont consider any of the above to be due to any other cause than 146K on it and not at all unreasonable (IMHO)
I'm having the steering/suspension overhauled soon - and then it will be pretty much "As New" & i fully intend keeping it until i can afford a W204 estate in a couple of years (me likes lots )
rob
were those early 203's not made in south africa?
