miro
Who's Richard?
Any chance to locate this place? May be the mytichal Area 51
Americans call Area 51 according to location on the map and the Germans would certainly have annother 50 factories.
Who's Richard?
2F is Germany
Look at the sticker inside the drivers door opening it should say...wait for it...
'Made in Germany' Hurray!
the early ones and a lot were made in south africa
maybe yours was not.
what i am saying is a lot of RHD's were made in south africa
but all LHD's were made in germany.
Miro, From your experience, what milage would you say wheel bearings need a seeing to ?I should point out that ALL W203 have the need for the following
- wheel bearings
- thrust arm bushes
- sway bushes
When neglected these lead to poor road feel and crap handling feel.
Also, "Thrust arm bushes and sway arms" I think you may be using different terminology from what I am used to. What parts are these on the front end. English (or even better, Scottish) name would be better for me. ?
Understand this fully, or the rubbers could "twist" and the angles of everthing change, when the suspension settles in it's running position with the weight of the car. Thanks.The REALLY IMPORTANT thing about doing bushes is that they must be loose when the wheels are not on the car. They can only be tightened under load using a 4 post hoist with the car rolling on its wheels or a prop under the suspension.
Can someone please post this A271 wire harness part number, my dealer cannot find it.For the engine you remove the cam magnet connection and "wash" the connector onto a white rag. If the oil stains are on the rag there then you have to install the "spacer" harness (A271 part number) and "wash" all of the other connections. The Engine controller has to be taken out also and held upside down for several hours to see if it holds any oil. If it holds oil it has to be opened and flushed with circuit board cleaner.
"Defining the series types in the W203 family
- 2000-2002 First type with obscure ESP module and annoying airbag 4 pins.
- 2002-2003 Inbetween series with better electronics and old engine type
- 2003-2004 M271 powered series FIRST UHI series.
- 2004-2005 Facelift version
- 2006-2007 Refined version with self-braking on speed limiter"
What isthe easiest way to tell if a 2004 C Class is pre or post facelifted model?
injectors should not be failing
