I contemplated changing mine but extraction of any charge and then recharge then a second extract and re-charge if it leaked anywhere put me off - a lot of trips to the gas man.
Yes, I agree but I am still tempted to have a go if it's a simple case of slotting the new one down the front of the rad and attaching the inlet/outlet pipes...
Great... thanks for that I will investigate later... Just for info.. the condenser has leaked from a breach in the lower pipe when a supporting bracket has rubbed through.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
