QUTSELL
Warning light on the dash,Engine fault,drive the car back home,appears to be missing on one plug,but still running ok,home after couple of minutes,i lift the bonnet,and sounds comeing from the n/s made me think its bad,so switch off and leave it,call an indi,who looked at it yesterday,pluged in Snap On to find the answer,(from previous experience Snap On will not show all faults),anyhow he tried to re`start the engine,obviously no start,he seems to think it can be the Camshaft sensor,but as in the past that's just chasing,in other words fit a part, if that is not the cure try another,such as the Crankshaft sensor,and so on,so I will let him fit the one part,then stop,if that is not the fix,obviously then call in a mechanic with the Starr.
