C-Class 220 CDi (W205) (2015) - Auxiliary battery problem
starlight
Scotland
C220d AMG Premium Line Plus (2018)
This question relates to the above C-Class, just under 4 years old, with only 23,000 miles on the clock.
The "Auxiliary Battery Malfunction" warning flashed up on the instrument cluster a couple of days ago. Although the warning isn't critical - and the car is perfectly driveable - the warning continued to flash every few seconds. Remember when malfunctions alerts simply came up and could then be stored in the malfunction memory without being a pest?
Anyway... the next day I took the car for a run of about 50 miles or so and the warning disappeared.
I've being trying to figure out - so far without success - whether the problem could have arisen because the car isn't often used for anything other than short local journeys; and it really doesn't need replaced.
I have an approved used warranty expiring next month that would cover a replacement. I'll probably take out a Tier 1 warranty after that, but I'm not sure it would provide cover for this. That policy has a lot of wriggle room in the area of "fair wear and tear".
So, the question is, at this low mileage, is it just possible there's no fault and the aux battery just needs a decent charge from time to time?
Incidentally, I have a feeling that the aux battery kicks in when the car stops in Eco Stop/Start mode, but I disable that at the start of every journey. Apart from being a pest, it hardly ever works. In fact, it will only work when the weather is blistering hot; and where I live that doesn't happen very often.
Gallon
UK Essex.
2015 S205 C200 AMG Premium Estate.
The (aux batt malfunction) warning is misleading, as your car doesn't have an aux battery, it has a large capacitor which Mercedes call a Voltage Converter. This is located in the passenger footwell below the glove box. They are known to fail & yours could be on it's way out.
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
The reason that your Stop/Start does not work is that your auxiliary battery (or capacitor, as above) is faulty.
The auxiliary battery provides power to the electrical consumers when the engine is not turning. This arrangement keeps the main battery free for starting the engine. Without the auxiliary battery, there's no power for electrical consumers and the engine won't switch off (i.e. Stop/Start won't work).
Once you have replaced the auxiliary battery, the Stop/Start functionality will work normally again (though you can obviously still switch it off if your don't like it).
OP
OP
S
starlight
Scotland
Thanks to Gallon and markjay for the helpful replies.
Although the problem seems to have gone away for the time being, I'll try to get it replaced under warranty at a service next month.
When the malfunction light was appearing, the fault didn't appear to have any effect on the availability of electrical consumers with the ignition off. The stop/start didn't work, but as I said in the original post it rarely does. I acquired the car about 10 months ago at around 19,000 miles. The function worked during hot summer weather and then packed up in the autumn. It worked briefly a couple of weeks ago on a very hot day. I know that a number of conditions need to be satisfied before it will kick-in: e.g., sufficient oil temperature. But I've also heard that it can sensitive to the ambient temperature.
markjay
MB Master
London
When the Stop/Start isn't operational, the main battery works as per normal i.e. it supplies both the starter motor and the other consumers. In fact there's no need to replace a faulty auxiliary battery if you don't care about the Stop/Start (but obviously if it's under warranty then it would not be sensible not to do so).
And although you are correct that there are a number of conditions required for the Stop/Start to work, 9 out of 10 it will be either a fulaty main battery or a faulty auxiliary battery - if either is not 100%, the Stop/Start won't work.
OP
OP
S
starlight
Scotland
Frankly, were it not for the infernal "nag" message about the malfunction in the instrument cluster - which IMO ought to be capable of being cancelled and stored in the case of a non-critical fault - in the light of what you say but for the warranty I wouldn't bother with a replacement.
GeeJayW
NW Blighty
S205 C250d AMG Line P+, MX-5 25th Anniversary Edition
Ours was replaced under warranty just over a year ago.
OP
OP
S
starlight
Scotland
... at the time of the repair, I should have said.
markjay
MB Master
London
Google:
"Auxiliary Battery Failure" Mercedes
Early failures (within the warranty period) are very common.
GeeJayW
NW Blighty
Bobclive2
slk 280
My C Class Coupe is Dec 2011 and has both original batteries, I don`t use stop/start. The reason your batteries are not being fully charged is due to the smart charging system where the engine management unit controls the alternator and won`t allow it to charge the battery from engine power when SOC is over 75%, this is to allow room for any regeneration, no regeneration no charge = near to flat battery if car is little used or does mainly short journeys , to test this just disconnect the sensor attached to the negative rail of the starter battery, drive the car for a few days, a few long runs would be good and the battery should then be near fully charged and remain so, you will loose stop/start and brake hold while the sensor is disconnected, there will be NO eml and your battery warning light should go out. Visit this link on the SLK forum, read to the end.
Start / Stop / eco tech a load of Bull ...... - Mercedes Benz SLK Forum
Bobclive2
slk 280
Quote "Auxiliary Battery Failure" Mercedes
Early failures (within the warranty period) are very common. Quote.
Only if stop/start is implemented, disconnect the sensor get rid of stop/start and smart charging and Mercedes batteries will last as long as mine, by the way, my car also does mainly short journeys and is used as a second car.
markjay
MB Master
London
My 2013 W204 has both original batteries, and stop/start still works fine - I guess I'm lucky.
UrbanM
Surrey
C220d AMG LINE Premium Plus
That’s so useful. I’m having The same issues.
OP
OP
S
starlight
Scotland
Update my end: The auxiliary battery was replaced and since then the stop/start function hasn't worked once... the amber icon stays on all the time. In the two years I've had the car, the feature has only worked on a handful of occasions, usually on a long run in hot weather.
UrbanM
Surrey
Thanks for the update. Much appreciated.
RTR1879
Mercedes Benz C350e Sport
Mine is doing the same thing. Start/stop has worked very rarely since I got the car in November (67 plate C220d AMG Line), probably 2 or 3 times in total and not at all since probably mid-December. I think I'll give the dealers a call tomorrow and get it looked at under warranty.
wongl
Surrey and Hong Kong
A180CDI, B200d, C300h, SLK250
Try giving your main batteries an overnight charge with a reliable charger and see if your star/stop will work. Chances are your main battery does not have sufficient charge to satisfy the start/stop condition.
