C class sports coupe broken door speaker help!
230KOMPRESSOR
Hi my mum has a 200k c class sports coupe, some how the speaker on the drivers side door has broken (not the actual speaker ) but the plastic bit that surrounds it/ covers it.
What i am getting at is can i change this little part or do i need a whole new door card ?
Thanks Ell
You want what is called the speaker cover front right [beside the door hinge]
Part no is possibly A2037270888 ???but you will have to specify the trim colour e.g.
alpaca grey/quartz/black/anthracite
Go to your local dealer with your mum's car VIN NO and the exact location of the speaker and they will order itand any securing clips needed for you- they probably won't have it in stock and you may have to pay in advance
Yes the other posts are quite correct I recently purchased a cover for my 203 coupe & changed it last Saturday. You need to remove the door card then drill out the plastic plugs for the speaker cover replace with new cover & then melt the ends of the pins on the new cover. I used a 100w soldering iron, I understand that Jay uses an old heater plug. Job took about 1 1/2 hours and the cover cost £24 + vat.
Dave
