Hi i wonder if anyone can help, ive been searching posts but not found any with exact same problem, my c200 estate was working perfectly i drove it home from work left it for a couple of hours then went back to it to find the car open which i thought was strange but maybe id forgot to lock it, i put key in ignition & it will not move at all, tried a few times moving wheel & turning but no luck, i then tried to lock car & the central locking will not work either, i replaced batteries in key fob but it will still not work, i can open drivers door with silver key which is is side of fob, but it only works on drivers door, have also tried disconnecting battery, any suggestions would be appreciated
