Solihull
Car is a 2004 CLK 270 CDi W209
Reg: YD04 ZFJ
VIN #: WDB2093162F102235
ESP failed warning light on dash
I used a iCarsoft Scanner i980 to read the DFC.
The code reads:
"C1035 - Signal from N49 (Steering Angle Sensor) is faulty"
In addition all of the following have also stopped working
Windscreen Wipers
Turn Indicators
Cruise control
Head Light flasher
No fault code have been found by the scanner or reported via the dash screen for any of those additional issues:
Could the Steering Angle Sensor (SAS) failure cause all this?
I'm willing to replace the SAS if required but given the cost I just want to try to be sure that doing so will provide a fix to the problems.
I'm based in the UK
Thank you for any help/guidance you can provide
Reg: YD04 ZFJ
The code reads:
Windscreen Wipers
Turn Indicators
Cruise control
Head Light flasher
I'm based in the UK
