C124 - Rear Window NOT WORKING!!!!
charan_singh
....any ideas on where to start with this one guys?
Switch or open up the door.....or is there some special little manual winder somewhere??!??!?!?!
...its currently getting wet..well semi wet in the rain after being taped up with a bin liner....;(
Tinkerer
Norfolk
W210 E220 CDi
When mine failed I took off the door trim and could push the glass back up by hand, it also revealed that the regulator arm had failed. Just note that the door trim may have to be in place to stop the alarm going off if you decide not to refit while you source new parts. Regulator arm fitting is pretty straight forward only needed a pop rivet gun from machine mart which came with a selection of rivets for £10 I think.
Hope all goes well.
StevenN
Nottingham
E220 CDI 2002 W210 Auto
I had a window rear window stop going up.
it turned out to be crap in the seal.
scraped clean and sprayed with ptfe now fine
