RSAtech
good day all,
i have a 2013 C180 merc that is acting up.
what the car does, if you pull out of the shop and you give it a bit off gas then the handbrake light comes one tells you that you are driving with the handbrake on the power steering stops working an the airbag light comes on, this lasts for about 3 seconds then all the lights goes off and then everything is fine again but the car has no power at all but there is no warning lights on if you switch the car off and start it again then she runs fine, we first suspected that its the battery we tested the battery and found it to be dead so we replaced it and its still doing the same thing. i inspected the ECU connectors for a pin that maybe pulled back but didn't find any did the same on the abs controller, i removed the left front carpet to inspect the can junction box (if you can call it that) but didn't find any moisture.
what can you suggest for me to have a look at?
thanks in advance
thanks in advance
