c180 block key not turning in ignition???
slimromeo
hi all,
ive got a 98 c180, the key works fine with the central locking but will not turn at all in the ignition???
any ideas?
Have you tried the spare key?
This fault will either the key or a dodgy EIS switch, new key approx. £215, EIS switch £400+.
you cannot recode the keys so the cheap second hand ones from E-bay will be a waste of money.
EIS switch has to be coded to you specific car, so a second hand one is a no-go too.
My first thing would be to get the fault codes read as this may give an indication on which item is to blame.
