jellyyacht
Hi Guys,
I'm a newb to this forum, so firstly, hello to all.
I have a strange problem with the central locking on my 1996 C180. I've followed the similar threads on the forum but none of the problems are exactly the same as mine.
The problem first manifested itself as the front doors would lock but the rear doors wouldn't. They would if I held down the button for longer, hmm. Same with my spare fob.
Then all locking packed up. I changed the batteries in the fob and it worked again, once, then stopped again.
I tried disconnecting the battery (one solution on another thread). No difference.
I tried resetting the system using the 2 clicks and turn the key to position 2. It worked. After resetting it all the doors unlocked and the open close button on the dash worked a treat, all doors opening and locking perfectly and without the engine on so it was using the vacuum pump. Great thought I. I used the keyfob to lock the car and again only the front doors locked, then nothing worked again. I tried to reset the system again and it doesn't seem to work/reset with either fob.
Any ideas please would be very welcome, MB at Newport want £87.50 + vat per hour to look at it.
Ouch!
Ouch!
