simyc1
Hi all,
I've searched through all the old posts, but can't find the same problem and therefore solution, so hopefully someone out there knows.
a) I've a 93 C180, (and still have no idea what these W123 no's mean).
b) I do not have any remote central locking ie No fancy button to press to lock the doors from my car keys.
c) I do not have the fancy folding down headrests
d) I do have the button on the console to press if i'm in the car.
Problem
1) All doors except the front passenger door, lock when I use my key in the drivers door. Why might this be happening??? I presume i have one of those vacuum systems i've read about... so how does it work???
2) Added to this the lock for the fuel cap, does not work and a motor, trying its best to work sound is coming from behind the fuel cap somewhere. Is this something I can fix and how??
3) Finally and more intersestingly, when I'm inside the car and press the locking button on the console, both rear doors lock, the motor once again is noisey coming from the fuel cap area of the car, is doing its best to lock the rest - (Drivers and front passenger, and probably the fuel cap too).
What is interesting about this though is that with the slightest of assistance, basically a tiny tiny touch to the little door locking pin, it disappears below the door panel and locks. This happens on both the drivers and front passengers doors.
Basically then all the doors have the ability to lock, but for some reason need a bit of assistance, any tips for a newbie Merc Owner, and have a go hero diy mechanic
Thanks in advance
Simyc1
Problem
Thanks in advance
Simyc1
