So, my engine has exactly 311113 km
Never had any breakdown, but engine is in kinda bad shape outside.
There is oil on spark plug holes and on the sides of engine. I need to change valve cover and 4 o-rings for each spark plug.
It needs a new catalytic converter, and some welding jobs.
It's misfireing on idle and sometimes when going downhill,
(This is related to oil leak,and cables. I won't change spark plugs till leak problem is solved.)
My engine wiring harness is in bad condition, cable insulation is falling from wires here and there.
I would like to ask some questions:
Does anyone had similar symptoms with oil leak past o-rings?
Why does some M111 engines have yellow stains on valve cover?
Why does it have oil in intake manifold??This is what I worry about
Does it means bad cylinder rings or something?
And last one: I want to rebuild engine wiring harness.
What part of harness should I rebuild and what size of wire to use?
