1995 C180 Manual Saloon Esprit, no aircodnition. If the ignition is turned on, the lights behind the two circular heater controls flash rapidly.
Engine starts OK, lights still flash. Once the side lights are swithed on the flashing stops, but the back light lights go out and stay out.
Also, the engine temperature builds up to normal, yet the fan will only blow mild hot air even though the tempurate thumb wheels are set to blue (cold).
Anyone had the same problem and what should I look for?
