c180 k bottom arm 52 plate
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by bellshill, Jun 30, 2011.
  1. bellshill
    bellshill New Member
    7
    Sep 21, 2009
    hi there looking for some help
    fitted o/s bottom arm no problem with swapping over now steering is way off centre and esp light on and ideas guys
    cheers
  2. carat 3.6
    carat 3.6 MB Enthusiast
    3,923
    May 11, 2011
    Buckinghamshire, yuppie central 1985.
    Car:
    96 e300d, 88 w124 superturbodiesel, 90 bmw E30 v8, + "others"
    This shouldnt afect your steering! What did you remove to change the arm?
  3. OP
    OP
    bellshill
    7
    Sep 21, 2009
    only removed the 2 21 mm bolts its as if the wheel is sitting in could it be wrong part
  4. carat 3.6
    3,923
    May 11, 2011
    Car:
    Did you check the new part against the old one?
Tags:
Share This Page
